Here is my INIT c iam using in KmotionCNC. Its same as the one i use in Mach3 just a new name.
#define FEEDHOLDBIT 21 #define MANUALBIT 25
#define X 0 #define Y 1 #define Z 2 #define A 3 void ServiceEStop(void);
int flast=0,flastsolid=-1,fcount=0; int mlast=0,mlastsolid=-1,mcount=0;
int Manual,FeedHold; int Debounce(int n, int *cnt, int *last, int *lastsolid);
main() { #define DROIN 40 double *pin = (double *)&persist.UserData[(DROIN -1)*2]; int result;
Manual = !ReadBit(MANUALBIT);
ch0->InputMode=ENCODER_MODE; ch0->OutputMode=CL_STEP_DIR_MODE; ch0->Vel=25000; ch0->Accel=180000; ch0->Jerk=18000000; ch0->P=0; ch0->I=0.005; ch0->D=0; ch0->FFAccel=0; ch0->FFVel=0; ch0->MaxI=200; ch0->MaxErr=1000000; ch0->MaxOutput=200; ch0->DeadBandGain=0; ch0->DeadBandRange=7; ch0->InputChan0=0; ch0->InputChan1=0; ch0->OutputChan0=8; ch0->OutputChan1=0; ch0->MasterAxis=-1; ch0->LimitSwitchOptions=0x1010000f; ch0->InputGain0=2.952759981155; ch0->InputGain1=1; ch0->InputOffset0=0; ch0->InputOffset1=0; ch0->OutputGain=1; ch0->OutputOffset=0; ch0->SlaveGain=1; ch0->BacklashMode=BACKLASH_OFF; ch0->BacklashAmount=0; ch0->BacklashRate=0; ch0->invDistPerCycle=1; ch0->Lead=0; ch0->MaxFollowingError=200; ch0->StepperAmplitude=20;
ch0->iir[0].B0=1; ch0->iir[0].B1=0; ch0->iir[0].B2=0; ch0->iir[0].A1=0; ch0->iir[0].A2=0;
ch0->iir[1].B0=1; ch0->iir[1].B1=0; ch0->iir[1].B2=0; ch0->iir[1].A1=0; ch0->iir[1].A2=0;
ch0->iir[2].B0=0.0007688089972362; ch0->iir[2].B1=0.001537619973533; ch0->iir[2].B2=0.0007688089972362; ch0->iir[2].A1=1.920809984207; ch0->iir[2].A2=-0.9238849878311;
ch1->InputMode=ENCODER_MODE; ch1->OutputMode=CL_STEP_DIR_MODE; ch1->Vel=25000; ch1->Accel=180000; ch1->Jerk=18000000; ch1->P=0; ch1->I=0.008; ch1->D=0; ch1->FFAccel=0; ch1->FFVel=0; ch1->MaxI=200; ch1->MaxErr=1000000; ch1->MaxOutput=200; ch1->DeadBandGain=0; ch1->DeadBandRange=7; ch1->InputChan0=1; ch1->InputChan1=0; ch1->OutputChan0=9; ch1->OutputChan1=0; ch1->MasterAxis=-1; ch1->LimitSwitchOptions=0x1111000f; ch1->InputGain0=-2.952759981155; ch1->InputGain1=1; ch1->InputOffset0=0; ch1->InputOffset1=0; ch1->OutputGain=1; ch1->OutputOffset=0; ch1->SlaveGain=1; ch1->BacklashMode=BACKLASH_OFF; ch1->BacklashAmount=0; ch1->BacklashRate=0; ch1->invDistPerCycle=1; ch1->Lead=0; ch1->MaxFollowingError=200; ch1->StepperAmplitude=20;
ch1->iir[0].B0=1; ch1->iir[0].B1=0; ch1->iir[0].B2=0; ch1->iir[0].A1=0; ch1->iir[0].A2=0;
ch1->iir[1].B0=1; ch1->iir[1].B1=0; ch1->iir[1].B2=0; ch1->iir[1].A1=0; ch1->iir[1].A2=0;
ch1->iir[2].B0=0.0007688089972362; ch1->iir[2].B1=0.001537619973533; ch1->iir[2].B2=0.0007688089972362; ch1->iir[2].A1=1.920809984207; ch1->iir[2].A2=-0.9238849878311;
ch2->InputMode=ENCODER_MODE; ch2->OutputMode=CL_STEP_DIR_MODE; ch2->Vel=25000; ch2->Accel=180000; ch2->Jerk=18000000; ch2->P=0; ch2->I=0.007; ch2->D=0; ch2->FFAccel=0; ch2->FFVel=0; ch2->MaxI=200; ch2->MaxErr=1000000; ch2->MaxOutput=200; ch2->DeadBandGain=0; ch2->DeadBandRange=5; ch2->InputChan0=2; ch2->InputChan1=0; ch2->OutputChan0=10; ch2->OutputChan1=0; ch2->MasterAxis=-1; ch2->LimitSwitchOptions=0x1212000f; ch2->InputGain0=2.952759981155; ch2->InputGain1=1; ch2->InputOffset0=0; ch2->InputOffset1=0; ch2->OutputGain=-1; ch2->OutputOffset=0; ch2->SlaveGain=1; ch2->BacklashMode=BACKLASH_OFF; ch2->BacklashAmount=0; ch2->BacklashRate=0; ch2->invDistPerCycle=1; ch2->Lead=0; ch2->MaxFollowingError=200; ch2->StepperAmplitude=20;
ch2->iir[0].B0=1; ch2->iir[0].B1=0; ch2->iir[0].B2=0; ch2->iir[0].A1=0; ch2->iir[0].A2=0;
ch2->iir[1].B0=1; ch2->iir[1].B1=0; ch2->iir[1].B2=0; ch2->iir[1].A1=0; ch2->iir[1].A2=0;
ch2->iir[2].B0=0.0007689999765716; ch2->iir[2].B1=0.001537999953143; ch2->iir[2].B2=0.0007689999765716; ch2->iir[2].A1=1.920809984207; ch2->iir[2].A2=-0.9238849878311; ch3->InputMode=NO_INPUT_MODE; ch3->OutputMode=STEP_DIR_MODE; ch3->Vel=2500000; ch3->Accel=1000000; ch3->Jerk=9000; ch3->P=0; ch3->I=0.005; ch3->D=0; ch3->FFAccel=0; ch3->FFVel=0; ch3->MaxI=200; ch3->MaxErr=1e+006; ch3->MaxOutput=200; ch3->DeadBandGain=1; ch3->DeadBandRange=0; ch3->InputChan0=3; ch3->InputChan1=0; ch3->OutputChan0=11; ch3->OutputChan1=0; ch3->MasterAxis=-1; ch3->LimitSwitchOptions=0x0; ch3->InputGain0=1; ch3->InputGain1=1; ch3->InputOffset0=0; ch3->InputOffset1=0; ch3->OutputGain=1; ch3->OutputOffset=0; ch3->SlaveGain=1; ch3->BacklashMode=BACKLASH_OFF; ch3->BacklashAmount=0; ch3->BacklashRate=0; ch3->invDistPerCycle=1; ch3->Lead=0; ch3->MaxFollowingError=1000000000; ch3->StepperAmplitude=20;
ch3->iir[0].B0=1; ch3->iir[0].B1=0; ch3->iir[0].B2=0; ch3->iir[0].A1=0; ch3->iir[0].A2=0;
ch3->iir[1].B0=1; ch3->iir[1].B1=0; ch3->iir[1].B2=0; ch3->iir[1].A1=0; ch3->iir[1].A2=0;
ch3->iir[2].B0=0.000769; ch3->iir[2].B1=0.001538; ch3->iir[2].B2=0.000769; ch3->iir[2].A1=1.92081; ch3->iir[2].A2=-0.923885;
// check if the User wants Manual Mode if (Manual) { chan[X].OutputMode = STEP_DIR_MODE; chan[Y].OutputMode = STEP_DIR_MODE; } else { chan[X].OutputMode = CL_STEP_DIR_MODE; chan[Y].OutputMode = CL_STEP_DIR_MODE; }
// enable/disable limits based on a // DRO downloaded from Mach3 if (*pin == 0) { ch0->LimitSwitchOptions = 0x1010000f; ch1->LimitSwitchOptions = 0x1111000f; ch2->LimitSwitchOptions = 0x1212000f; } else { ch0->LimitSwitchOptions = 0x0; ch1->LimitSwitchOptions = 0x0; ch2->LimitSwitchOptions = 0x0; }
EnableAxisDest(0,ch0->Position); EnableAxisDest(1,ch1->Position); EnableAxisDest(2,ch2->Position); EnableAxisDest(3,ch3->Dest);
DefineCoordSystem(0,1,2,3);
for (;;) { Manual = !ReadBit(MANUALBIT); // handle switching into or out of Manual Mode result = Debounce(Manual,&mcount,&mlast,&mlastsolid); if (result == 1) { // just entered manual mode DisableAxis(X); DisableAxis(Y); DisableAxis(Z); chan[X].OutputMode = STEP_DIR_MODE; chan[Y].OutputMode = STEP_DIR_MODE; chan[Z].OutputMode = STEP_DIR_MODE; EnableAxisDest(X,chan[X].Position); EnableAxisDest(Y,chan[Y].Position); EnableAxisDest(Z,chan[Z].Position);
printf("Simulated Manual Mode on\n"); } if (result == 0) { // just entered auto mode DisableAxis(X); DisableAxis(Y); DisableAxis(Z); chan[X].OutputMode = CL_STEP_DIR_MODE; chan[Y].OutputMode = CL_STEP_DIR_MODE; chan[Z].OutputMode = CL_STEP_DIR_MODE;
EnableAxisDest(X,chan[X].Position); EnableAxisDest(Y,chan[Y].Position); EnableAxisDest(Z,chan[Z].Position); printf("Simulated Manual Mode off\n"); printf("Pulse Estop\n"); Delay_sec(1); }
// handle Feedhold FeedHold = ReadBit(FEEDHOLDBIT); result = Debounce(FeedHold,&fcount,&flast,&flastsolid); if (result == 1) { // just entered Feed Hold mode StopCoordinatedMotion(); //feedhold }
WaitNextTimeSlice(); }
return 0; }
// Debounce a bit // // return 1 one time when first debounced high // return 0 one time when first debounced low // return -1 otherwise #define DBTIME 300
int Debounce(int n, int *cnt, int *last, int *lastsolid) { int v = -1; if (n == *last) // same as last time? { if (*cnt == DBTIME-1) { if (n != *lastsolid) { v = *lastsolid = n; // return debounced value } } if (*cnt < DBTIME) (*cnt)++; } else { *cnt = 0; // reset count } *last = n; return v; }
Troy
