Hi Bob,
Normally a C Program is used to completely initialize the system before running GCode. The C program will configure all the settings of all the axes, enable all the axes, define which axes are used by the GCode coordinate system, and anything else required by your system (ie enable amplifiers). This approach provides total flexibility on how to configure and initialize any system. Once the C program is created using the KMotion.exe program it is no longer necessary to run KMotion.exe. Any application such as KMotionCNC or Mach3 can completely configure and initialize your system just by running the C program.
The C statement below will Enable Axis 2 and set its destination to zero.
EnableAxisDest(2,0);
The C statement below will configure Axis Channels 0, 1, 2 as GCode X,Y, and Z with axis A unused
DefineCoordSystem(0,1,2,-1);
The Flash Video below might help understand the overall scheme of the process.
