Hi Troy,
It is possible to use Kanalog with Step/Dir outputs but there are limitations as it consumes KFLOP's JP7 and JP5 connectors where the Step/Dir Outputs normally come out.
By unplugging JP5 from KFLOP to Kanalog you can still have access to 4 KFLOP Step/Dir outputs. But this reduces the number of differential receivers on Kanalog from 16 to 8. Everything else on Kanalog will function the same.
There is also another option to Mux the 4 Step/Dir Outputs from JP5 to JP4 and JP6 (2 each). But only one on each of JP4 and JP6 can then be used in open collector mode. It this manner you retain all 16 of Kanalog's differential inputs.
If you are interested I can provide more details.
TK --- On Wed, 8/24/11, Troy <groups@...> wrote:
From: Troy <groups@...> Subject: Re: [DynoMotion] ENCODER RECOMENDATION To: DynoMotion@yahoogroups.com Date: Wednesday, August 24, 2011, 11:44 AM
I am guessing my steppers will be spinning under 2400rpm. I suppose I need to get one of my slides hooked up and see how fast my motors can spin under load. I was planning on getting the differential encoders. I was working on a breakout board design for myself with the Ti encoder decode chip and some level shifters for the non 5v tollerant I/Os. Instead of making my own board could I do the same thing with kanalog, and my steppers, I would rather work on other parts of my project then designing a circuit board, I just assumed kanalog was for servos only?
Message: 1732 |
Date: 8/24/2011 |
| Subject: Re: ENCODER RECOMENDATION |
I looked at those but they seem to have a lot less resolution then my 2500cpr=10000ppr resolution encoders. If I understand the datasheet properly I think those encoders are not optical encoders they are capacitive and they say they are limited to 2048ppr. I am still not sure whether I need the 10000ppr resolution, but it seems as long as long as I don't over do the rpms there is no harm in using the higher resolution encoders.
Message: 1734 |
Date: 8/25/2011 |
Hi TK Well, I am pretty far along with my board, and I am shooting for 6 axis of closed loop steppers, so it might be easier for me to just keep trucking along with my board design. Maybee you can answer this for me, are you familiar with the amc26v32 differential line receiver (is this what you used on the kanalog, it seems pretty common)? If so do you know what I should do with G and Ginv. On the chart in the datasheet it looks like I should pull one high and one low. Thanks Troy
Message: 1735 |
Date: 8/25/2011 |
Hi Troy,
I can't find a reference for that part number, but it is probably a variation of the one we use which is AM26LS32ACD. The G and /G are the enables. Set G high and /G low.
TK --- On Thu, 8/25/11, Troy <groups@...> wrote:
From: Troy <groups@...> Subject: Re: [DynoMotion] ENCODER RECOMENDATION To: DynoMotion@yahoogroups.com Date: Thursday, August 25, 2011, 3:23 PM
Hi TK
Thanks Troy
