Hi Ray,
s[-1] : since s is a pointer into the middle of a char array then s[-1] is the char one slot before where s points.
The first parameter (PERSIST+1) is not a pointer. It is an offset into the gather_buffer for where the string is located. It is passed at the very beginning so the offset is set to zero. The gather_buffer is sort of a general purpose global block of 8MBytes of SDRAM.
Message: 3556 |
Date: 1/29/2012 |
| Subject: Re: Coupla Stupid Questions.... |
Ah! That's what I was missing.... Thanks. It's working now.
Ray L.
> Hi Ray,
> s[-1]Â : since s is a pointer into the middle of a char array then s[-1] is the char one slot before where s points.
> Sent: Sunday, January 29, 2012 8:35 AM
> Subject: [DynoMotion] Coupla Stupid Questions....
> I'm working on the PCComm methods, and am finding some seemingly simple things that I'm, just not grok'ing.
> 1) In the DSP code for PC_COMM_MSG, I find the following code:
> int MsgBox(char *s, int Flags)
> char *p=(char *)gather_buffer+GATH_OFF*sizeof(int);
> int i;
> do // copy to gather buffer w offset 0
> *p++ = *s++;
> }while (s[-1]);
> persist.UserData[PC_COMM_PERSIST+2] = Flags; // set options
> DoPCInt(PC_COMM_MSG,GATH_OFF);
> return persist.UserData[PC_COMM_PERSIST+3];
> Two things confuse me here:
> First, is the "while (s[-1]);". That's obviously being used to detect the end of the string, but how? What is at s[-1]??
> Second, as I understand this method, PC_COMM_PERSIST is set to PC_COMM_MSG and PC_COMM_PERSIST+1 should be set as a pointer to the string. But PC_COMM_PERSIST+1 doesn't get set at all here?? And, indeed, when I try to use PC_COMM_PERSIST+1 as the string offset, I get garbage.
> Regards,
> Ray L.
Message: 3557 |
Date: 1/29/2012 |
Except now I'm back to crashing on the Persist write to clear the command word....
> Tom,
> Regards,
> Ray L.
> > Hi Ray,
> > Â
> > Â
> > Â
> > Â
> > int i;
> > *p++ = *s++;
> > }while (s[-1]);
> > Regards,
> > Ray L.
