Hi easydigisoft,
KFLOP JP5 are single ended inputs you can connect it directly.
That chip would be good for converting to differential for Kanalog's differential
inputs.
Message: 8148 |
Date: 8/23/2013 |
| Subject: Re: Connecting single ended signal encoder |
Can you please show me how to connect it to JP5 and simple c code example? Also if I use the IC can you show me c code example for that too? I am little confused here. Thank you.
> Hi easydigisoft,
> That chip would be good for converting to differential for Kanalog's differential inputs.
> From: easydigisoft <easydigisoft@...>
> Sent: Friday, August 23, 2013 12:27 PM
> Subject: [DynoMotion] Connecting single ended signal encoder
> Can someone please explain me how can I connect single ended signal encoder on KFLOP JP5 connector?
> I also found this IC http://www.ti.com/lit/ds/symlink/ds26ls31c.pdf
> Will this IC work to convert it to A+A- B+B- ?
> Thanks.
Message: 8150 |
Date: 8/23/2013 |
Hi easydigisoft, A single ended encoder usually has A, B, +5V, GND. Connect A to KFLOP JP5 Pin1 and B to KFLOP JP5 Pin2. See: http://dynomotion.com/Help/SchematicsKFLOP/ConnectorsKFLOP.htm KFLOP JP5 doesn't have +5V and GND so you will need to connect those to another connector or the supply. You should then see the A B signals toggling when the encoder moves on the Digital IO Screen Bits 36 and 37. Then configure an Axis Channel as encoder input and with InputChan0 = 4 When the encoder moves you should see the Position change on the Axis Screen. HTH Regards TK
Message: 8151 |
Date: 8/23/2013 |
OK I'll test that, thank you very much.
> Hi easydigisoft,
> See:Â http://dynomotion.com/Help/SchematicsKFLOP/ConnectorsKFLOP.htm
> HTH
> Sent: Friday, August 23, 2013 12:34 PM
> Subject: [DynoMotion] Re: Connecting single ended signal encoder
> > Hi easydigisoft,
> > From: easydigisoft <easydigisoft@>
> > ÃÂ
> > Thanks.
