I am wanting to use 6 stepper drivers, and am purchasing 2 KSteps to do so. I would like to run closed loop with Quadrature encoders. I am having some trouble finding locations for all of my encoders and drives.
The KSteps would be plugged in to JP7 and JP5. Is it possible to plug in 5V encoders to JP6 or JP4? All of my encoders are 5V and I am a bit concerned about 3.3V only on these connections. Would I need to buy another breakout board? Would the Konnect board inputs be suitable for encoder connections?
Any suggestions you have would be helpful, I may end up using 8 steppers, but no coordinated motion on motors 7 and 8.
Scott
Group: DynoMotion
Message: 11394
Date: 4/15/2015
Subject: Re: Connect Encoders Through Konnect
Hi Scott,
The 8 Encoder inputs can be multiplexed over to KFLOP JP4 and JP6. See the MuxEncoders.c example.
The JP4 and JP6 encoder inputs are 3.3V only inputs with 150 ohm termination. They will be damaged if driven hard above 3.85V because they are diode clamped to the 3.3V supply. Most 5V TTL drivers do not drive too high and if they do only very weakly. They are only required to drive above a minimum of 2.8V to be a valid TTL high. But unfortunately most devices do not specify a maximum high level. I have never seen a case where this is a problem. You might test your encoder outputs under a 150ohm load to see if they drive above 3.85V. Or you might add a 47 ohm series resistor to be absolutely safe.
Konnect inputs are not suitable as encoder inputs.
Group: DynoMotion
Message: 11395
Date: 4/15/2015
Thanks for the reply. To ensure I understand, all I need to do is add the following line to my main program into my startup program:
Once I do that, how do I know which of the pins on JP4 and JP6 are applicable to each axis?
I am using US Digital encoders, do you have any experience with this brand? I would rather not have to solder resisters onto the inputs. Sounds like the risk of frying the KFlop board is pretty minimal?
