Hi Benny,
#1 "Stop" will issue an immediate hardware feedhold to KFlop so the motion will begin to stop immediately without a need to flush the motion buffer. "Reset" will also cause Mach3 to disable the amplifier enables so the motion will also begin to stop immediately. However because MS Windows is not real-time responsive, pushing any button on a Windows Screen is not 100% reliable in stopping motion. On most Windows systems the response to a button press is usually nearly instant 99% of the time. To get 100% reliability instant feedhold you must wire an external switch directly to KFlop that can initiate hardware feed hold.
#2 Yes issuing a hardware feedhold to KFlop either through an externally wired button or a custom Mach3 Screen button will cause KFlop to stop immediately along the current path. Releasing the feedhold will resume motion smoothly along the same path. However with hardware feedhold Mach3 is not really aware that the machine has stopped, so it is not possible to issue other Mach3 commands such as Jogs or changing offsets. You must first depress "Stop" in Mach3.
#3 This is a common misunderstanding. When defined as inputs the pins ARE floating. KFlop uses MOSFET inputs which have extremely high input resistance (> 10 Meg Ohms). That is why they change more or less randomly and possibly track the signals closest to them due to parasitic resistance and capacitance. This is normal. Inputs that are not connected to anything are not defined and may have any value high or low. If nothing is connected to the input then nothing should care what the state is. We used to apply weak pull down resistors to avoid this confusion but this caused problems using pins in "open collector" mode as the pin would never go fully "open".
I hope this helps
Message: 942 |
Date: 3/6/2011 |
| Subject: Re: Buffer issue in mach3 |
Hi TK,
Thanks for your reply, for question 3, it is okay, I understanding, if we use the pin, we should not put it in floating state. However, for Q1 and Q2, I am a little but confuse, could you please elaborate more on following area?
1. there are 3 sec of motion buffer in Mach3, is it store in mach3 or downloaded to kflop hardware buffer?
2. If I press the "feedhold" button in Mach3, mach3 will stop to feed the instruction to kflop and the buffered motions will continue running until the buffer empty, right after I press the "start" button again in mach3, the motion will continue and there should no missed step or instruction, right?
3. If I press the "stop" button in mach3, the mach3 and kflop will stop immediatly, then how about the content in the buffer? Are they being erase?
4. You said there is a hardware feedhold in kflop, how can we make use of it? If we use this hardware feedhold, how can we keep mach3 and kflop syncronized (make mach3 and flop stop at the same time)
5. What is the difference if I press "stop" and "reset" in mach3?
6. From kflop point of view, is there any concept of "reset", "emergency, "stop" and "feed"? Or just received instruction from Mach3 ?
Best regards,
Benny
> Hi Benny,
> hardware feed hold.
> in Mach3.
> track the signals closest to them due to parasitic resistance and capacitance.Â
> I hope this helps
> TKÂ
> From: likleong <likleong@...>
> Sent: Sun, March 6, 2011 5:59:27 AM
> Subject: [DynoMotion] Buffer issue in mach3
> Hi TK,
> I have the following questions regarding to mach3 and kflop:
> 1. There are 3 sec buffer in mach3 plugin, is it meaning that, there will be 3
> sec of motion command will be download to kflop's motion buffer? that means even
> mach3 stopped with "stop" or "reset" button, the kflop will keep running for 3
> sec until buffer empty, right?
> 2. In case of some emergency situation, in spit of hardware EMG stop, is there
> any way to stop the mach3 and kflop immediately but keep the contents in motion
> buffer so that it can resume within mache?
> 3. I found that, some IO pins (eg, IO42, IO43), if I define them as Input and
> keep them floating, normally, they will read as low, however, if I put One of
> them high, both of them will read high, until I ground the another one, is it
> normal? Is it not possible to put the input pin floating?
> Bes reagrds,
> Benny
Message: 943 |
Date: 3/7/2011 |
Hi Benny,
Regarding:
#1 - some of both actually.
#2 - Yes the normal Mach3 feedhold works like that. However Mach3 doesn't really stop feeding instructions, rather it changed the instructions to a decelerated motion along the path and then a fixed location.
#3 - Yes, Stop flushes all the buffers.
#4 - Below is a simple program (ExternalFeedhold.c example) to watch an I/O bit and perform hardware feedhold when the input goes high. Mach3 naturally stays in sync because it doesn't even know it happened. From its perspective the motion is just taking a long time to execute and the buffer pipeline remains full.
for (;;) // loop forever
WaitNextTimeSlice();
if (ReadBit(46)) // Watch an external input switch
StopCoordinatedMotion(); //feedhold
#5 - Basically Stop - stops the motion, Reset - disables al the axes and requires a re-initialization.
#6 - KFlop basically receives instructions from Mach3
Message: 944 |
Date: 3/7/2011 |
Hi TK,
Is it meaning that,
1. Only "feedhold" button in mach3 can stop the running code without lost step and motion instruction and then continue after the pause.
2. The hardware feedhold in kflop is actually monitor the input pin by c program and then call a routine to stop/disable all the axis,and all the contents in motion buffer will also be erase.
3. Both hardware feedhold and "stop" button in mach3 will immediately motion the motion, however the buffered instruction will be lost. If we use hardware feedhold, there is no way to notify mach3 when hardware feedhold enabled in kflop.
Best regards,
Benny
> Hi Benny,
> Regarding:
> #1 -Â some of both actually.
> full. Â
> #include
> main()
> {"KMotionDef.h"   for(;;) // loop forever   {
> Â Â Â Â Â Â WaitNextTimeSlice();Â Â Â Â Â Â if(ReadBit(46)) // Watch an external input
> switch      {
>          StopCoordinatedMotion(); //feedhold      }
> Â Â Â }
> Sent: Sun, March 6, 2011 11:41:08 PM
> Subject: [DynoMotion] Re: Buffer issue in mach3
> Hi TK,
> Best regards,
> Benny
> > Hi Benny,
> > #1 "Stop" will issue an immediateÃÂ hardware feedhold to KFlop so the motion
> >will
> > begin to stop immediately without a need to flush the motion buffer.ÃÂ "Reset"
> > begin to stop immediately.ÃÂ However because MS Windows is not real-time
> > stopping motion.ÃÂ On most Windows systems the response to a button press is
> > usually nearly instant 99% of the time.ÃÂ To get 100% reliability instant
> > hardware feed hold.
> > along the current path.ÃÂ Releasing the feedhold will resume motion smoothly
> > along the same path.ÃÂ However with hardware feedhold Mach3 is not really aware
> > commands such as Jogs or changing offsets.ÃÂ You must first depress "Stop"
> > inÃÂ Mach3.
> > #3 This is a common misunderstanding.ÃÂ When defined as inputs the pins ARE
> > floating.ÃÂ KFlop uses MOSFET inputs which have extremely high input resistance
> > (> 10 Meg Ohms).ÃÂ That is why they change more or less randomly andÃÂ possibly
> >capacitance.ÃÂ
> > This is normal.ÃÂ ÃÂ Inputs that are not connected to anything are not defined
> >and
> > may have any value high or low.ÃÂ If nothing is connected to the input then
> > nothing should care what the state is.ÃÂ We used to applyÃÂ weak pull down
> > I hope this helps
> > TKÃÂ
> > From: likleong <likleong@>
> > ÃÂ
> > Hi TK,
> >even
> > Bes reagrds,
> > Benny
Message: 945 |
Date: 3/8/2011 |
Hi Benny,
#1 - No. It is also possible to resume instant hardware feedhold without lost steps.
#2 - No. The hardware does not disable the axes or erase the buffer. Basically KFlop slows down to a stop and stops taking motion from the buffer. The buffer remains full. To resume Kflop again starts taking motion from the buffer.
#3 - No. Buffered instructions will not be lost. Mach3 is always waiting for there to be space in the buffer. Whenever there becomes space available it fills the buffer. After KFlop stops consuming motion the buffer will remain full and Mach3 will wait.
The only problem with hardware feedhold is with issuing other commands while in feedhold. For example the tool breaks. You hit hardware feedhold and the machine instantly stops. But now you want to Jog the machine, change the tool, adjust a work offset, etc.., then resume. Before doing this you must push Stop in Mach3.
Message: 947 |
Date: 3/8/2011 |
Hi TK,
Okay, for kflop HW feedhold, there is no step lost. for mach2 feedhold, there is also no step lost, but need to waiting for couple of sec until buffer empty, and may be risk of slow respond from windows, right?
Then, how about the "stop" in mach3? you said the buffer contents will be erase in last reply. Is it related to kflop HW feedhold or just use another way to stop immedately?
Finally, if I ignore the respond issue from windows and just use the feedhold in mach3, is there any way to make the mach 3 issue a feedhold command to kflop immedately(StopCoordinatedMotion) without waiting the buffer to empty?
Best regards,
Benny.
> Hi Benny,
> steps.
> Stop in Mach3.Â
> Sent: Mon, March 7, 2011 11:38:26 PM
> Hi TK,
> Is it meaning that,
> kflop.
> Best regards,
> Benny
> > Hi Benny,
> > Regarding:
> > #1 -ÃÂ some of both actually.
> > #2 - Yes the normal Mach3 feedhold works like that.ÃÂ However Mach3 doesn't
> > #4 - Below is a simple programÃÂ (ExternalFeedhold.c example)ÃÂ to watch an I/O
> >bit
> > and perform hardware feedhold when the input goes high.ÃÂ Mach3 naturally stays
> > in sync because it doesn't even know it happened.ÃÂ From its perspective the
> > full.ÃÂ ÃÂ
> > #include
> > main()
> > {"KMotionDef.h"ÃÂ ÃÂ ÃÂ for(;;) // loop foreverÃÂ ÃÂ ÃÂ {
> > ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ WaitNextTimeSlice();ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ if(ReadBit(46)) // Watch an
> >external input
> > switchÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ {
> > ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ StopCoordinatedMotion(); //feedholdÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ }
> > ÃÂ ÃÂ ÃÂ }
> > #6 - KFlop basicallyÃÂ receives instructions from Mach3
> > ÃÂ
> > Hi TK,
> >downloaded
> >If
> >(make
> >"stop"
> > Best regards,
> > Benny
> > > Hi Benny,
> > > #1 "Stop" will issue an immediateÃâàhardware feedhold to KFlop so the motion
> > >will
> > > begin to stop immediately without a need to flush the motion buffer.ÃâÃÂ
> >"Reset"
> >also
> > > begin to stop immediately.ÃâàHowever because MS Windows is not real-time
> > > stopping motion.ÃâàOn most Windows systems the response to a button press
> >is
> > > usually nearly instant 99% of the time.ÃâàTo get 100% reliability instant
> > > hardware feed hold.
> >wired
> > > along the current path.ÃâàReleasing the feedhold will resume motion
> >smoothly
> > > along the same path.ÃâàHowever with hardware feedhold Mach3 is not really
> >aware
> > > commands such as Jogs or changing offsets.ÃâàYou must first depress "Stop"
> > > inÃâàMach3.
> > > #3 This is a common misunderstanding.ÃâàWhen defined as inputs the pins ARE
> > > floating.ÃâàKFlop uses MOSFET inputs which have extremely high input
> >resistance
> > > (> 10 Meg Ohms).ÃâàThat is why they change more or less randomly
> >andÃâàpossibly
> > >capacitance.ÃâÃÂ
> > > This is normal.ÃâàÃâàInputs that are not connected to anything are not
> >defined
> > >and
> > > may have any value high or low.ÃâàIf nothing is connected to the input then
> > > nothing should care what the state is.ÃâàWe used to applyÃâàweak pull down
> >"open
> > > I hope this helps
> > > Regards
> > > TKÃâÃÂ
> > > ÃâÃÂ
> > > Hi TK,
> >3
> > >even
> >3
> >there
> >motion
> > > Bes reagrds,
> > > Benny
Message: 948 |
Date: 3/9/2011 |
Hi Benny,
Regarding question #1 - Exactly Correct.
Regarding question #2 - I'm not sure exactly what you are asking - but I think the Mach3 manual states that "Stop" is likely to loose steps as it abruptly stops generating motion and flushes its buffers. In our plugin we attempt to issue a hardware feedhold, then after coming to a stop, flush our buffers, then re-sync the position with Mach3. So it should be instant and with no loss of steps, but not necessarily resume-able.
Regarding question #3 - Yes. To issue a hardware feedhold from a Mach3 screen you will need to modify a Mach3 screen to add or change the functionality of a button to issue a NotifyPlugins(XX) message. This will cause your Notify C program to execute in KFlop and pass it the message XX. (Message numbers 10000 - 10999 will be passed to KFLOP). You can then code your Notify C program to issue the StopCoordinatedMotion().
Message: 949 |
Date: 3/9/2011 |
Hi TK,
Do you have any idea how to modify the existing "feedhold" button in mach3, on top of the existing function, also make it issue a NotifyPlugins(XX) message to klop. On the other hand, how to handle the resume after the above feedhold? Thanks.
Best regards,
Benny
> Hi Benny,
> Regarding question #2 -Â I'm not sure exactly what you are asking - but I think
> TKÂ
> Sent: Tue, March 8, 2011 11:02:52 PM
> Hi TK,
> stop immedately?
> Best regards,
> Benny.
> > Hi Benny,
> > #1 - No.ÃÂ It is also possible to resume instant hardware feedhold without lost
> > steps.
> > #2 - No.ÃÂ The hardware does not disable the axes or erase the buffer.ÃÂ
> >Basically
> > KFlop slows down to a stop and stops taking motion from the buffer.ÃÂ The
> >buffer
> > remains full.ÃÂ To resume Kflop again starts taking motion from the buffer.
> > #3 -ÃÂ No.ÃÂ Buffered instructions will not be lost.ÃÂ ÃÂ Mach3 is always waiting
> >for
> > there to be space in the buffer.ÃÂ Whenever there becomes space available it
> > fills the buffer.ÃÂ AfterÃÂ KFlop stopsÃÂ consuming motion the buffer will remain
> >whileÃÂ in
> > feedhold.ÃÂ For example the tool breaks.ÃÂ You hit hardware feedhold and the
> > machine instantly stops.ÃÂ But now you want to Jog the machine, change the
> > tool,ÃÂ adjust a work offset, etc.., then resume.ÃÂ Before doing this you must
> >push
> > Stop in Mach3.ÃÂ
> > ÃÂ
> > Hi TK,
> > Is it meaning that,
> >program
> >the
> > kflop.
> > Best regards,
> > Benny
> > > Hi Benny,
> > > Regarding:
> > > #1 -Ãâàsome of both actually.
> > > #2 - Yes the normal Mach3 feedhold works like that.ÃâàHowever Mach3 doesn't
> > > #4 - Below is a simple programÃâà(ExternalFeedhold.c example)Ãâàto watch an
> >I/O
> > >bit
> > > and perform hardware feedhold when the input goes high.ÃâàMach3 naturally
> >stays
> > > in sync because it doesn't even know it happened.ÃâàFrom its perspective
> >the
> > > full.ÃâàÃâÃÂ
> > > #include
> > > main()
> > > {"KMotionDef.h"ÃâàÃâàÃâàfor(;;) // loop foreverÃâàÃâàÃâà{
> > > ÃâàÃâàÃâàÃâàÃâàÃâàWaitNextTimeSlice();ÃâàÃâàÃâàÃâàÃâàÃâÃÂ
> > >external input
> > > switchÃâàÃâàÃâàÃâàÃâàÃâà{
> > > ÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàStopCoordinatedMotion();
> >//feedholdÃâàÃâàÃâàÃâàÃâàÃâà}
> > > ÃâàÃâàÃâà}
> > > #6 - KFlop basicallyÃâàreceives instructions from Mach3
> > > Regards
> > > ÃâÃÂ
> > > Hi TK,
> >a
> > >downloaded
> >motion
> > >If
> > >(make
> > >"stop"
> > > Best regards,
> > > Benny
> > > > Hi Benny,
> > > > #1 "Stop" will issue an immediateÃÆ'ââ¬Å¡Ãâàhardware feedhold to KFlop so the
> >motion
> > > >will
> >buffer.ÃÆ'ââ¬Å¡ÃâÃÂ
> > >"Reset"
> > >also
> > > > begin to stop immediately.ÃÆ'ââ¬Å¡ÃâàHowever because MS Windows is not
> >real-time
> > > > stopping motion.ÃÆ'ââ¬Å¡ÃâàOn most Windows systems the response to a button
> >press
> > >is
> > > > usually nearly instant 99% of the time.ÃÆ'ââ¬Å¡ÃâàTo get 100% reliability
> >instant
> >initiate
> > > > hardware feed hold.
> > >wired
> > > > along the current path.ÃÆ'ââ¬Å¡ÃâàReleasing the feedhold will resume motion
> > >smoothly
> > > > along the same path.ÃÆ'ââ¬Å¡ÃâàHowever with hardware feedhold Mach3 is not
> >really
> > >aware
> > > > commands such as Jogs or changing offsets.ÃÆ'ââ¬Å¡ÃâàYou must first depress
> >"Stop"
> > > > inÃÆ'ââ¬Å¡ÃâàMach3.
> > > > #3 This is a common misunderstanding.ÃÆ'ââ¬Å¡ÃâàWhen defined as inputs the
> >pins ARE
> > > > floating.ÃÆ'ââ¬Å¡ÃâàKFlop uses MOSFET inputs which have extremely high input
> > >resistance
> > > > (> 10 Meg Ohms).ÃÆ'ââ¬Å¡ÃâàThat is why they change more or less randomly
> > >andÃÆ'ââ¬Å¡Ãâàpossibly
> > > >capacitance.ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > This is normal.ÃÆ'ââ¬Å¡ÃâÃÂ ÃÆ'ââ¬Å¡ÃâàInputs that are not connected to anything
> >are not
> > >defined
> > > >and
> > > > may have any value high or low.ÃÆ'ââ¬Å¡ÃâàIf nothing is connected to the
> >input then
> > > > nothing should care what the state is.ÃÆ'ââ¬Å¡ÃâàWe used to
> >applyÃÆ'ââ¬Å¡Ãâàweak pull down
> > >"open
> > > > I hope this helps
> > > > Regards
> > > > TKÃÆ'ââ¬Å¡ÃâÃÂ
> > > > ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > Hi TK,
> >be
> > >3
> > > >even
> >for
> > >3
> > >there
> > >motion
> >and
> >of
> >it
> > > > Bes reagrds,
> > > > Benny
Message: 950 |
Date: 3/9/2011 |
Hi Benny,
Read this and see if you still have questions. Look for information on the Mach3 site on how to change the screens. We recommend the one written by Klaus Dietz.
If you change the Cycle Start button to do:
NotifyPlugins(11000)
The Cycle Start button should resume if KFlop is in the Hardware Feedhold state, otherwise it will do a normal Cycle Start.
Let me know if it isn't clear.
Message: 951 |
Date: 3/10/2011 |
Hi TK,
Thanks, I will try it out. I have another question regarding to the IO pins in kflop, can I define a general IO pin as output and in open collector at the same time? If I want to use the IO pin to drive a relay, any suggestion? Thanks.
Best regards,
Benny
> Hi Benny,
> Mach3 site on how to change the screens. Â We recommend the one written by Klaus
> Dietz.Â
> http://www.dynomotion.com/Help/Mach3Plugin/Mach3Encoders.htm
> NotifyPlugins(11000)Â
> Sent: Wed, March 9, 2011 5:31:06 PM
> Hi TK,
> Thanks.
> Best regards,
> Benny
> > Hi Benny,
> > Regarding question #2 -ÃÂ I'm not sure exactly what you are asking - but I think
> > stops generating motion and flushes its buffers.ÃÂ In our plugin we attempt to
> > re-sync the position with Mach3.ÃÂ So it should be instant and with no loss of
> > Regarding question #3 - Yes.ÃÂ To issue a hardware feedhold from a Mach3 screen
> > you will need to modifyÃÂ a Mach3 screen to add or change the functionality of a
> > button to issue a NotifyPlugins(XX) message.ÃÂ This will causeÃÂ your Notify C
> > program to execute in KFlop and pass it the message XX.ÃÂ ÃÂ (Message numbers
> >10000
> > - 10999 will be passed to KFLOP).ÃÂ You can then code your Notify C program to
> > TKÃÂ
> > ÃÂ
> > Hi TK,
> >is
> >and
> > stop immedately?
> >in
> > Best regards,
> > Benny.
> > > Hi Benny,
> > > #1 - No.ÃâàIt is also possible to resume instant hardware feedhold without
> >lost
> > > steps.
> > > #2 - No.ÃâàThe hardware does not disable the axes or erase the buffer.ÃâÃÂ
> > >Basically
> > > KFlop slows down to a stop and stops taking motion from the buffer.ÃâàThe
> > >buffer
> > > remains full.ÃâàTo resume Kflop again starts taking motion from the
> buffer.
> > > #3 -ÃâàNo.ÃâàBuffered instructions will not be lost.ÃâàÃâàMach3 is always
> >waiting
> > >for
> > > there to be space in the buffer.ÃâàWhenever there becomes space available
> >it
> > > fills the buffer.ÃâàAfterÃâàKFlop stopsÃâàconsuming motion the buffer
> >will remain
> > >whileÃâàin
> > > feedhold.ÃâàFor example the tool breaks.ÃâàYou hit hardware feedhold and
> >the
> > > machine instantly stops.ÃâàBut now you want to Jog the machine, change the
> > > tool,Ãâàadjust a work offset, etc.., then resume.ÃâàBefore doing this you
> >must
> > >push
> > > Stop in Mach3.ÃâÃÂ
> > > Regards
> > > ÃâÃÂ
> > > Hi TK,
> > > Is it meaning that,
> >step
> > >program
> > >the
> > > kflop.
> > > Best regards,
> > > Benny
> > > > Hi Benny,
> > > > Regarding:
> > > > #1 -ÃÆ'ââ¬Å¡Ãâàsome of both actually.
> > > > #2 - Yes the normal Mach3 feedhold works like that.ÃÆ'ââ¬Å¡ÃâàHowever Mach3
> >doesn't
> > > > #4 - Below is a simple programÃÆ'ââ¬Å¡Ãâà(ExternalFeedhold.c
> >example)ÃÆ'ââ¬Å¡Ãâàto watch an
> > >I/O
> > > >bit
> > > > and perform hardware feedhold when the input goes high.ÃÆ'ââ¬Å¡ÃâàMach3
> >naturally
> > >stays
> > > > in sync because it doesn't even know it happened.ÃÆ'ââ¬Å¡ÃâàFrom its
> >perspective
> > >the
> >remains
> > > > full.ÃÆ'ââ¬Å¡ÃâÃÂ ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > #include
> > > > main()
> > > > {"KMotionDef.h"ÃÆ'ââ¬Å¡ÃâÃÂ ÃÆ'ââ¬Å¡ÃâÃÂ ÃÆ'ââ¬Å¡Ãâàfor(;;) // loop
> >foreverÃÆ'ââ¬Å¡ÃâÃÂ ÃÆ'ââ¬Å¡ÃâÃÂ ÃÆ'ââ¬Å¡Ãâà{
> > > > ÃÆ'ââ¬Å¡ÃâÃÂ ÃÆ'ââ¬Å¡ÃâÃÂ ÃÆ'ââ¬Å¡ÃâÃÂ ÃÆ'ââ¬Å¡ÃâÃÂ ÃÆ'ââ¬Å¡ÃâÃÂ ÃÆ'ââ¬Å¡ÃâÃÂ
> >WaitNextTimeSlice();ÃÆ'ââ¬Å¡ÃâÃÂ ÃÆ'ââ¬Å¡ÃâÃÂ ÃÆ'ââ¬Å¡ÃâÃÂ ÃÆ'ââ¬Å¡ÃâÃÂ ÃÆ'ââ¬Å¡ÃâÃÂ ÃÆ'ââ¬Å¡ÃâÃÂ
> > > >external input
> > > > switchÃÆ'ââ¬Å¡ÃâÃÂ ÃÆ'ââ¬Å¡ÃâÃÂ ÃÆ'ââ¬Å¡ÃâÃÂ ÃÆ'ââ¬Å¡ÃâÃÂ ÃÆ'ââ¬Å¡ÃâÃÂ ÃÆ'ââ¬Å¡Ãâà{
> >ÃÆ'ââ¬Å¡ÃâÃÂ ÃÆ'ââ¬Å¡ÃâÃÂ ÃÆ'ââ¬Å¡ÃâàStopCoordinatedMotion();
> > >//feedholdÃÆ'ââ¬Å¡ÃâÃÂ ÃÆ'ââ¬Å¡ÃâÃÂ ÃÆ'ââ¬Å¡ÃâÃÂ ÃÆ'ââ¬Å¡ÃâÃÂ ÃÆ'ââ¬Å¡ÃâÃÂ ÃÆ'ââ¬Å¡Ãâà}
> > > > #6 - KFlop basicallyÃÆ'ââ¬Å¡Ãâàreceives instructions from Mach3
> > > > Regards
> > > > TK
> > > > ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > Hi TK,
> >use
> >am
> > >a
> > > >downloaded
> >the
> > >motion
> >it?
> > > >If
> > > >(make
> > > >"stop"
> > > > Best regards,
> > > > Benny
> > > > > Hi Benny,
> > > > > #1 "Stop" will issue an immediateÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡Ãâàhardware feedhold to
> >KFlop so the
> > >motion
> > > > >will
> > >buffer.ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
> > > >"Reset"
> > > >also
> > > > > begin to stop immediately.ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâàHowever because MS Windows
> >is not
> > >real-time
> >in
> > > > > stopping motion.ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâàOn most Windows systems the response
> >to a button
> > >press
> > > >is
> > > > > usually nearly instant 99% of the time.ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâàTo get 100%
> >reliability
> > >instant
> > >initiate
> > > > > hardware feed hold.
> > > >wired
> >immediately
> > > > > along the current path.ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâàReleasing the feedhold will
> >resume motion
> > > >smoothly
> > > > > along the same path.ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâàHowever with hardware feedhold
> >Mach3 is not
> > >really
> > > >aware
> > > > > commands such as Jogs or changing offsets.ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâàYou must
> >first depress
> > >"Stop"
> > > > > inÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâàMach3.
> > > > > #3 This is a common misunderstanding.ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâàWhen defined as
> >inputs the
> > >pins ARE
> > > > > floating.ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâàKFlop uses MOSFET inputs which have
> > > >resistance
> > > > > (> 10 Meg Ohms).ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâàThat is why they change more or less
> >randomly
> > > >andÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡Ãâàpossibly
> > > > >capacitance.ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > > This is normal.ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâàInputs that are
> > >are not
> > > >defined
> > > > >and
> > > > > may have any value high or low.ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâàIf nothing is
> >connected to the
> > >input then
> > > > > nothing should care what the state is.ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâàWe used to
> > >applyÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡Ãâàweak pull down
> > > >"open
> > > > > I hope this helps
> > > > > Regards
> > > > > TKÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > > ÃÆ'Ã'âââ¬Ã
Â¡ÃÆ'ââ¬Å¡ÃâÃÂ
> > > > > Hi TK,
> > >be
> > > >3
> >means
> > > > >even
> > >for
> > > >3
> > > >there
> > > >motion
> > >and
> >One
> > >of
> >is
> > >it
> > > > > Bes reagrds,
> > > > > Benny
Message: 952 |
Date: 3/11/2011 |
Hi Benny,
I assume you are trying to drive something like the +5V input of a SSR (Solid State Relay) in open collector mode and NOT something like a 12V relay.
From a User Program to drive an I/O pin low set the Bit low and set it as an Output with:
ClearBit(XX);
SetBitDirection(XX,1);
To set an I/O pin "open" set the pin as an input.
SetBitDirection(XX,0);
As an input the Pin will be able to "float" up to ~3.9V because it is diode clamped to the 3.3V supply.
Message: 953 |
Date: 3/11/2011 |
Hi TK,
May be my question is not clear enough, I want to use the kflop IO pin as an output to drive a 3v relay directly, but I am afraid the current is not enough, because the relay need 50 mA to operate. Is there any way to solve this problem? How about set the IO pin in open collector mode?
Best regards,
Benny
> Hi Benny,
> Output with:
> ClearBit(XX);
> Sent: Thu, March 10, 2011 11:28:57 PM
> Hi TK,
> Best regards,
> Benny
> > Hi Benny,
> > Read this and see if you still have questions.�� Look for information on the
> > Mach3 site on how to change the screens. ��We recommend the one written by
> >Klaus
> > Dietz.��
> > NotifyPlugins(11000)��
> >state,
> > Hi TK,
> > Thanks.
> > Best regards,
> > Benny
> > > Hi Benny,
> > > Regarding question #2 -��斾寉啱'm not sure exactly what you are asking - but I
> >think
> > > stops generating motion and flushes its buffers.��斾寉 In our plugin we attempt
> >to
> >then
> > > re-sync the position with Mach3.��斾寉 So it should be instant and with no loss
> >of
> > > Regarding question #3 - Yes.��斾寉 To issue a hardware feedhold from a Mach3
> >screen
> > > you will need to modify��斾寉乸 Mach3 screen to add or change the functionality
> >of a
> > > button to issue a NotifyPlugins(XX) message.��斾寉 This will cause��斾寉∂our
> >Notify C
> > > program to execute in KFlop and pass it the message XX.��斾寉ó钊�斾寉 (Message
> >numbers
> > >10000
> > > - 10999 will be passed to KFLOP).��斾寉 You can then code your Notify C program
> >to
> > > Regards
> > > TK��斾寉
> > > ��斾寉
> > > Hi TK,
> > >is
> > >and
> >erase
> > > stop immedately?
> > >in
> > > Best regards,
> > > Benny.
> > > > Hi Benny,
> > > > #1 - No.��â�¬Å¡Ã钊�斾寉 It is also possible to resume instant hardware feedhold
> >without
> > >lost
> > > > steps.
> > > > #2 - No.��â�¬Å¡Ã钊�斾寉 The hardware does not disable the axes or erase the
> >buffer.��â�¬Å¡Ã钊�斾寉
> > > >Basically
> >buffer.��â�¬Å¡Ã钊�斾寉 The
> > > >buffer
> > > > remains full.��â�¬Å¡Ã钊�斾寉 To resume Kflop again starts taking motion from the
> > buffer.
> > > > #3 -��â�¬Å¡Ã钊�斾寉嘅o.��â�¬Å¡Ã钊�斾寉脷uffered instructions will not be
> >lost.��â�¬Å¡Ã钊�斾寉ó纱黒¢ââ\Å¡��斾寉嗰ach3 is always
> > >waiting
> > > >for
> > > > there to be space in the buffer.��â�¬Å¡Ã钊�斾寉 Whenever there becomes space
> >available
> > >it
> > > > fills the buffer.��â�¬Å¡Ã钊�斾寉 After��â�¬Å¡Ã钊�斾寉嗱Flop stops��â�¬Å¡Ã钊�斾寉氲onsuming
> >motion the buffer
> > >will remain
> > > >while��â�¬Å¡Ã钊�斾寉湶n
> > > > feedhold.��â�¬Å¡Ã钊�斾寉 For example the tool breaks.��â�¬Å¡Ã钊�斾寉 You hit hardware
> >feedhold and
> > >the
> > > > machine instantly stops.��â�¬Å¡Ã钊�斾寉 But now you want to Jog the machine,
> >change the
> > > > tool,��â�¬Å¡Ã钊�斾寉乸djust a work offset, etc.., then resume.��â�¬Å¡Ã钊�斾寉 Before
> >doing this you
> > >must
> > > >push
> > > > Stop in Mach3.��â�¬Å¡Ã钊�斾寉
> > > > Regards
> > > > TK
> > > > ��â�¬Å¡Ã钊�斾寉
> > > > Hi TK,
> > > > Is it meaning that,
> > >step
> > > >program
> >in
> >motion
> > > >the
> > > > kflop.
> > > > Best regards,
> > > > Benny
> > > > > Hi Benny,
> > > > > Regarding:
> > > > > #1 -���'�¢â�斵¬Ã埘¡Ã纱黒¢ââ\Å¡��斾寉澵ome of both actually.
> > > > > #2 - Yes the normal Mach3 feedhold works like that.���'�¢â�斵¬Ã埘¡Ã纱黒¢ââ\Å¡��斾寉
> >However Mach3
> > >doesn't
> > > > > #4 - Below is a simple program���'�¢â�斵¬Ã埘¡Ã纱黒¢ââ\Å¡��斾寉 (ExternalFeedhold.c
> > >example)���'�¢â�斵¬Ã埘¡Ã纱黒¢ââ\Å¡��斾寉濳o watch an
> > > >I/O
> > > > >bit
> >high.���'�¢â�斵¬Ã埘¡Ã纱黒¢ââ\Å¡��斾寉 Mach3
> > >naturally
> > > >stays
> > > > > in sync because it doesn't even know it happened.���'�¢â�斵¬Ã埘¡Ã纱黒¢ââ\Å¡��斾寉
> >From its
> > >perspective
> > > >the
> > >remains
> > > > > full.���'�¢â�斵¬Ã埘¡Ã纱黒¢ââ\Å¡��斾寉 ���'�¢â�斵¬Ã埘¡Ã纱黒¢ââ\Å¡��斾寉
> > > > > #include
> > > > > main()
> >{"KMotionDef.h"���'�¢â�斵¬Ã埘¡Ã纱黒¢ââ\Å¡��斾寉ó纱黒�'�¢â�斵¬Ã埘¡Ã纱黒¢ââ\Å¡��斾寉ó纱黒�'�¢â�斵¬Ã埘¡Ã纱黒¢ââ\Å¡��斾寉
> >for(;;) // loop
> > >forever���'�¢â�斵¬Ã埘¡Ã纱黒¢ââ\Å¡��斾寉ó纱黒�'�¢â�斵¬Ã埘¡Ã纱黒¢ââ\Å¡��斾寉ó纱黒�'�¢â�斵¬Ã埘¡Ã纱黒¢ââ\Å¡��斾寉 {
> >>WaitNextTimeSlice();���'�¢â�斵¬Ã埘¡Ã纱黒¢ââ\Å¡��斾寉ó纱黒�'�¢â�斵¬Ã埘¡Ã纱黒¢ââ\Å¡��斾寉ó纱黒�'�¢â�斵¬Ã埘¡Ã纱黒¢ââ\Å¡��斾寉
> >� ���'�¢â�斵¬Ã埘¡Ã纱黒¢ââ\Å¡��斾寉ó纱黒�'�¢â�斵¬Ã埘¡Ã纱黒¢ââ\Å¡��斾寉ó纱黒�'�¢â�斵¬Ã埘¡Ã纱黒¢ââ\Å¡��斾寉
> > > > >external input
> > > > > switch���'�¢â�斵¬Ã埘¡Ã纱黒¢ââ\Å¡��斾寉ó纱黒�'�¢â�斵¬Ã埘¡Ã纱黒¢ââ\Å¡��斾寉ó纱黒�'�¢â�斵¬Ã埘¡Ã纱黒¢ââ\Å¡��斾寉
> > > >//feedhold���'�¢â�斵¬Ã埘¡Ã纱黒¢ââ\Å¡��斾寉ó纱黒�'�¢â�斵¬Ã埘¡Ã纱黒¢ââ\Å¡��斾寉ó纱黒�'�¢â�斵¬Ã埘¡Ã纱黒¢ââ\Å¡��斾寉
> >���'�¢â�斵¬Ã埘¡Ã纱黒¢ââ\Å¡��斾寉ó纱黒�'�¢â�斵¬Ã埘¡Ã纱黒¢ââ\Å¡��斾寉ó纱黒�'�¢â�斵¬Ã埘¡Ã纱黒¢ââ\Å¡��斾寉 }
> > > > > #6 - KFlop basically���'�¢â�斵¬Ã埘¡Ã纱黒¢ââ\Å¡��斾寉澑eceives instructions from Mach3
> > > > > Regards
> > > > > TK
> > > > > Hi TK,
> > >use
> >I
> > >am
> > > >a
> > > > >downloaded
> > >the
> > > >motion
> >erase?
> > >it?
> > > > >If
> >syncronized
> > > > >(make
> > > > >"stop"
> > > > > Best regards,
> > > > > Benny
> > > > > > Hi Benny,
> >immediate���'�� '���¢�¢â�¬Å¡Ã寉¬Ã钊�¦Ã寉¡Ã纱黒�'�¢â�斵¬Ã埘¡Ã纱黒¢ââ\Å¡��斾寉温ardware feedhold to
> > >KFlop so the
> > > >motion
> > > > > >will
> > > >buffer.���'�� '���¢�¢â�¬Å¡Ã寉¬Ã钊�¦Ã寉¡Ã纱黒�'�¢â�斵¬Ã埘¡Ã纱黒¢ââ\Å¡��斾寉
> > > > >"Reset"
> >will
> > > > >also
> > > > > > begin to stop immediately.���'�� '���¢�¢â�¬Å¡Ã寉¬Ã钊�¦Ã寉¡Ã纱黒�'�¢â�斵¬Ã埘¡Ã纱黒¢ââ\Å¡��斾寉
> > >is not
> > > >real-time
> > >in
> > > > > > stopping motion.���'�� '���¢�¢â�¬Å¡Ã寉¬Ã钊�¦Ã寉¡Ã纱黒�'�¢â�斵¬Ã埘¡Ã纱黒¢ââ\Å¡��斾寉 On most
> > >to a button
> > > >press
> > > > >is
> >time.���'�� '���¢�¢â�¬Å¡Ã寉¬Ã钊�¦Ã寉¡Ã纱黒�'�¢â�斵¬Ã埘¡Ã纱黒¢ââ\Å¡��斾寉 To get 100%
> > >reliability
> > > >instant
> > > >initiate
> > > > > > hardware feed hold.
> >externally
> > > > >wired
> > >immediately
> > > > > > along the current path.���'�� '���¢�¢â�¬Å¡Ã寉¬Ã钊�¦Ã寉¡Ã纱黒�'�¢â�斵¬Ã埘¡Ã纱黒¢ââ\Å¡��斾寉
> > >resume motion
> > > > >smoothly
> > > > > > along the same path.���'�� '���¢�¢â�¬Å¡Ã寉¬Ã钊�¦Ã寉¡Ã纱黒�'�¢â�斵¬Ã埘¡Ã纱黒¢ââ\Å¡��斾寉 However
> > >Mach3 is not
> > > >really
> > > > >aware
> >Mach3
> >offsets.���'�� '���¢�¢â�¬Å¡Ã寉¬Ã钊�¦Ã寉¡Ã纱黒�'�¢â�斵¬Ã埘¡Ã纱黒¢ââ\Å¡��斾寉 You must
> > >first depress
> > > >"Stop"
> > > > > > in���'�� '���¢�¢â�¬Å¡Ã寉¬Ã钊�¦Ã寉¡Ã纱黒�'�¢â�斵¬Ã埘¡Ã纱黒¢ââ\Å¡��斾寉嗰ach3.
> > > > > > #3 This is a common
> >misunderstanding.���'�� '���¢�¢â�¬Å¡Ã寉¬Ã钊�¦Ã寉¡Ã纱黒�'�¢â�斵¬Ã埘¡Ã纱黒¢ââ\Å¡��斾寉 When defined as
> > >inputs the
> > > >pins ARE
> > > > > > floating.���'�� '���¢�¢â�¬Å¡Ã寉¬Ã钊�¦Ã寉¡Ã纱黒�'�¢â�斵¬Ã埘¡Ã纱黒¢ââ\Å¡��斾寉 KFlop uses MOSFET
> >inputs which have
> > > > >resistance
> > > > > > (> 10 Meg Ohms).���'�� '���¢�¢â�¬Å¡Ã寉¬Ã钊�¦Ã寉¡Ã纱黒�'�¢â�斵¬Ã埘¡Ã纱黒¢ââ\Å¡��斾寉 That is why
> > >randomly
> > > > >and���'�� '���¢�¢â�¬Å¡Ã寉¬Ã钊�¦Ã寉¡Ã纱黒�'�¢â�斵¬Ã埘¡Ã纱黒¢ââ\Å¡��斾寉漤ossibly
> > > > > >capacitance.���'�� '���¢�¢â�¬Å¡Ã寉¬Ã钊�¦Ã寉¡Ã纱黒�'�¢â�斵¬Ã埘¡Ã纱黒¢ââ\Å¡��斾寉
> > > > > > This is
> >normal.���'�� '���¢�¢â�¬Å¡Ã寉¬Ã钊�¦Ã寉¡Ã纱黒�'�¢â�斵¬Ã埘¡Ã纱黒¢ââ\Å¡��斾寉ó纱黒�'�� '���¢�¢â�¬Å¡Ã寉¬Ã钊�¦Ã寉¡Ã纱黒�'�¢â�斵¬Ã埘¡Ã纱黒¢ââ\Å¡��斾寉
> > Inputs that are
> > > >are not
> > > > >defined
> > > > > >and
> >low.���'�� '���¢�¢â�¬Å¡Ã寉¬Ã钊�¦Ã寉¡Ã纱黒�'�¢â�斵¬Ã埘¡Ã纱黒¢ââ\Å¡��斾寉 If nothing is
> > >connected to the
> > > >input then
> >is.���'�� '���¢�¢â�¬Å¡Ã寉¬Ã钊�¦Ã寉¡Ã纱黒�'�¢â�斵¬Ã埘¡Ã纱黒¢ââ\Å¡��斾寉 We used to
> > > >apply���'�� '���¢�¢â�¬Å¡Ã寉¬Ã钊�¦Ã寉¡Ã纱黒�'�¢â�斵¬Ã埘¡Ã纱黒¢ââ\Å¡��斾寉烀eak pull down
> >in
> > > > >"open
> > > > > > I hope this helps
> > > > > > Regards
> > > > > > TK���'�� '���¢�¢â�¬Å¡Ã寉¬Ã钊�¦Ã寉¡Ã纱黒�'�¢â�斵¬Ã埘¡Ã纱黒¢ââ\Å¡��斾寉
> > > > > > Hi TK,
> >will
> > > >be
> > > > >3
> > >means
> > > > > >even
> >running
> > > >for
> > > > >3
> >is
> > > > >there
> >in
> > > > >motion
> >Input
> > > >and
> > >One
> > > >of
> > >is
> > > >it
> > > > > > Bes reagrds,
> > > > > > Benny
Message: 954 |
Date: 3/11/2011 |
Hi Benny,
The 3.3V outputs can only source/sink 16ma. You would need some form of a driver. Or use a 3V Solid state relay.
Message: 955 |
Date: 3/11/2011 |
Hi Benny,
I admire tom his patience: His support of his product cannot include
teaching of electronics or full design of your application.
You need to investigate this on you own. Otherwise he will go insane
and none of us will get supported :-)
In this case you need to use the IO to drive and N channel
transistor( BJT or Mosfet ) that will then be able to supply the
current control of your
external device.
Please read:
http://www.scienceprog.com/interfacing-microcontrollers-to-external-devices/
http://www.diodes.com/_files/products_appnote_pdfs/zetex/an10.pdf
http://www.dnatechindia.com/index.php/Tutorials/8051-Tutorial/Relay-Interfacing.html
On 3/11/2011 10:16 AM, likleong wrote:
Hi TK,
mode?
Best regards,
Benny
> Hi Benny,
like a 12V relay.
> Output with:
> ClearBit(XX);
> Hi TK,
> Best regards,
> Benny
> > Hi Benny,
the
> >Klaus
> > Dietz.��
> >state,
> > Hi TK,
> > Thanks.
> > Best regards,
> > Benny
> > > Hi Benny,
-��斾寉啱'm
> >think
buffers.��斾寉
> >to
> >then
Mach3.��斾寉
> >of
Yes.��斾寉
> >screen
> > > you will need to
modify��斾寉乸
> >of a
message.��斾寉
This will
cause��斾寉∂our
> >Notify C
message
XX.��斾寉ó钊�斾寉
(Message
> >numbers
> > >10000
KFLOP).��斾寉
> >to
> > > Regards
TK��斾寉
mach3
��斾寉
> > > Hi TK,
> > >is
> > >and
right?
> >erase
> > > stop immedately?
> > >in
> > > Best regards,
> > > Benny.
> > > > Hi Benny,
> > > > #1 -
No.��â�¬Å¡Ã钊�斾寉
> >without
> > >lost
> > > > steps.
> > > > #2 -
No.��â�¬Å¡Ã钊�斾寉
>buffer.��â�¬Å¡Ã钊�斾寉
> > > >Basically
>buffer.��â�¬Å¡Ã钊�斾寉
The
> > > >buffer
> > > > remains
full.��â�¬Å¡Ã钊�斾寉
> > buffer.
> > > > #3
is always
> > >waiting
> > > >for
buffer.��â�¬Å¡Ã钊�斾寉
> >available
> > >it
> > > > fills the
buffer.��â�¬Å¡Ã钊�斾寉
> >motion the buffer
> > >will remain
>while��â�¬Å¡Ã钊�斾寉湶n
breaks.��â�¬Å¡Ã钊�斾寉
You hit hardware
> >feedhold and
> > >the
> > > > machine instantly
stops.��â�¬Å¡Ã钊�斾寉
> >change the
resume.��â�¬Å¡Ã钊�斾寉
Before
> >doing this you
> > >must
> > > >push
> > > > Stop in
Mach3.��â�¬Å¡Ã钊�斾寉
> > > > Regards
> > > > TK
in mach3
��â�¬Å¡Ã钊�斾寉
> > > > Hi TK,
> > > > Is it meaning that,
> > >step
> > > >program
> >in
> >motion
> > > >the
> > > > kflop.
> > > > Best regards,
> > > > Benny
> > > > > Hi Benny,
> > > > > Regarding:
> > > > > #1
of both actually.
feedhold works like
> >However Mach3
> > >doesn't
buffers.
watch an
> > > >I/O
> > > > >bit
when the input goes
Mach3
> > >naturally
> > > >stays
know it
> >From its
> > >perspective
> > > >the
> > >remains
> > > > > #include
> > > > > main()
> >for(;;) // loop
> > > > >external input
> > > > > #6 - KFlop
> > > > > Regards
> > > > > TK
PM
issue in mach3
> > > > > Hi TK,
> > >use
> >I
> > >am
> > > >a
> > > > >downloaded
> > >the
> > > >motion
> >erase?
> > >it?
> > > > >If
> >syncronized
> > > > >(make
time)
> > > > >"stop"
> > > > > Best regards,
> > > > > Benny
> > > > > > Hi Benny,
feedhold to
> > >KFlop so the
> > > >motion
> > > > > >will
> > > > >"Reset"
> >will
> > > > >also
> > > > > > begin to stop
> > >is not
> > > >real-time
> > >in
> > > > > > stopping
On most
> > >to a button
> > > >press
> > > > >is
of the
To get 100%
> > >reliability
> > > >instant
> > > >initiate
> > > > > > hardware feed hold.
> >externally
> > > > >wired
> > >immediately
> > > > > > along the current
> > >resume motion
> > > > >smoothly
> > > > > > along the same
However
> > >Mach3 is not
> > > >really
> > > > >aware
> >Mach3
changing
You must
> > >first depress
> > > >"Stop"
> > > > > > #3 This is a common
When defined as
> > >inputs the
> > > >pins ARE
KFlop uses MOSFET
> >inputs which have
> > > > >resistance
> > > > > > (> 10 Meg
That is why
> > >randomly
> > > > > > This is
;纱黒¢ââ\Å¡��斾寉
> > Inputs that are
> > > >are not
> > > > >defined
> > > > > >and
If nothing is
> > >connected to the
> > > >input then
state
We used to
pull down
> >in
> > > > >"open
(Message over 64 KB, truncated)
Message: 956 |
Date: 3/11/2011 |
Hi Lee,
Those are great links. Thanks.
(I have no problem trying to answer questions on the group as other users probably have the same issues)
Message: 957 |
Date: 3/11/2011 |
Hi Tom and Benny,
That's true. I was surprised at the lengths needed to find good
examples as I searched today. I have books
from way back when I learned that stuff. Steve Ciarcia's books on
building you own Z80
was classic! Had good thermal managment primer inside also.
WOW just found it in downloadable form( dated but highly
recommended!!!):
http://www.scribd.com/doc/13388965/Build-Your-Own-Z80-Computer
Benny,
Look especially at figure10 page6 of this appnote. It's simple and
will be perfect for
most reasonable open collector drive requirements.
On 3/11/2011 12:08 PM, Tom Kerekes wrote:
Hi Lee,
issues)
