Hi easydigisoft,
The SWE relay driver output is guaranteed to remain off until after all the Kanalog Outputs are initialized off. You will need to use that, or some other means of keeping everything disabled until after the Kanalog Outputs are initialized.
Message: 8121 |
Date: 8/19/2013 |
| Subject: Re: Bit status on startup |
what is SWE relay driver?
> Hi easydigisoft,
> From: easydigisoft <easydigisoft@...>
> Sent: Monday, August 19, 2013 11:20 AM
> Subject: [DynoMotion] Bit status on startup
> Ok so I am almost finished with connecting my cnc but when I power up the KFLOP and Kanalog it seems like for few seconds every pin goes high. At that moment everything is turned on, my chip, hidraulics pump, emulsion pump spindle, EVERYTHING. So it takes a lot of power and the fuse shuts it off. Is there a way to set KFLOP not to turn on all pins to high on startup? thanks.
Message: 8122 |
Date: 8/19/2013 |
Hi easydigisoft, Kanalog JP8 Pin9 see: http://dynomotion.com/Help/SchematicsKanalog/ConnectorsKanalog.htm Regards TK
Message: 8123 |
Date: 8/19/2013 |
Thank you very much, but I have 12 outputs that I use for pumps, hidraulics, servo enables etc etc. Where can I find relay with 12 contacts?
> Hi easydigisoft,
> Sent: Monday, August 19, 2013 12:36 PM
> Subject: [DynoMotion] Re: Bit status on startup
> > Hi easydigisoft,
> > The SWE relay driver output is guaranteed to remain off until after all the Kanalog Outputs are initialized off.ÃÂ You will need to use that, or some other means of keeping everything disabled until after the Kanalog Outputs are initialized.
> > From: easydigisoft <easydigisoft@>
> > ÃÂ
Message: 8124 |
Date: 8/19/2013 |
These are dirt cheap and can be hacked in many ways.
http://www.aliexpress.com/item/FREE-SHIPPING-5V-8-Channel-Relay-Module-Board-for-Arduino-PIC-AVR-MCU-DSP-ARM/905836992.html
>> Hi easydigisoft,
>> Regards
>> TK
>> Â
>>> Hi easydigisoft,
>>> Regards
>>> TK
>>> ÂÂ
> Yahoo! Groups Links
Message: 8126 |
Date: 8/19/2013 |
Hi easydigisoft,
Can't you switch the main power(s)?
Message: 8127 |
Date: 8/19/2013 |
maybe common hi-side drivers for relay
groups.
On 8/19/2013 4:08 PM, Tom Kerekes wrote:
Hi easydigisoft,
main power(s)?
