Group: DynoMotion Message: 6362 From: himykabibble Date: 12/31/2012
Subject: Aborting A Toolchange
I've just completed the toolchanger for my mill, but I want to add a means to allow a toolchange to fail gracefully due, for example, to a mechanical fault. Right now, M6 runs a KFlop program that performs the toolchange, which leaves me no way that I can see of returning a status that says "Completed" or "Failed". The "Completed" case would be simply a NOP, allowing execution to continue, while "Failed" should abort any G-code program in-process, and notify the user of the nature of the fault. How can I accomplish this without modifying the Interpreter (again)?
BTW - Happy New Year!
Ray L.
Group: DynoMotion Message: 6371 From: Tom Kerekes Date: 1/1/2013
Subject: Re: Aborting A Toolchange
Hi Ray,
There isn't a direct mechanism for returning error codes from MCode C Programs as they run as a separate thread in separate hardware (KFLOP).
I think you will need to have your Tool Change program set some indication of a failure that your application will then need to detect and do whatever you wish (Halt).
KMotionCNC has a mechanism for sending commands to the PC (KMotionCNC) that include issuing a Halt.  I would suggest you follow the same technique in the Application you wrote.  The GetStatus Uploading process includes a few UserData variables that are intended for this purpose.  KMotionCNC monitors these locations for commands that indicate it should do something (like tell the interpreter to Halt).
So in summary:
#1 In case of a failure during a tool change do a :      DoPC(PC_COMM_HALT);    see KFLOPtoPCCmdExamples.c
#2 Add into your Application's Status update process a monitor for such commands.  There is a .NET export of GetPC_Comm_Status to obtain the communication words.  Duplicate the functionality that KMotionCNC does to process commands in void CKMotionCNCDlg::ServiceKFLOPCommands()
Group: DynoMotion Message: 6372 From: Tom Kerekes Date: 1/1/2013
Hi Ray,
So in summary:
Group: DynoMotion Message: 6373 From: himykabibble Date: 1/1/2013
That should handle it. Thanks!
BTW - Here's my toolchanger. Not fast, but it's been dead reliable.
http://www.youtube.com/watch?v=zjGi1WBTMBE
Ray L.
> Hi Ray,
> So in summary:
> HTH
> From: himykabibble <jagboy1964@...>
> Sent: Monday, December 31, 2012 9:20 PM
> Subject: [DynoMotion] Aborting A Toolchange
> Tom,
> Regards,
> Ray L.
