Hi Frank, Have you tried configuring A into the XYZA coordinate system with something like: DefineCoordSystem(0,1,-1,2); Then try the A100 command in Mach3.Do you have a Z axis?
Message: 6495 |
Date: 1/16/2013 |
| Subject: Re: A command gcodes |
Have you defined an A axis in Mach3 mapped to the spindle channel on the KFlop?
Ray L.
--- In DynoMotion@yahoogroups.com, "frank_19_88" wrote:
> Hi Tk,
> I have a milling machine most functions working fine.
> With s1000 the spindle start turning exact 1000rpm.(with encoder)
> And if I use move(2,500) within the kflop console the spindle move 1/4th of a rev.
> But I want to do this with mach3. (I think we need the A command)
> But if I send A100, the kflop receive nothing and I can not find any vb script for the A command.
> Hope you can help.
> Frank
Message: 6551 |
Date: 1/23/2013 |
Hello Ray and TK,
Thank you for your reply,
I did forget to run A axis on at mach 3.
A command is working fine now. :)
But next problem; if I use m3 the a axis start move .
Is it possible to move te A axis 180deg within the gcode program? (if I don't know the position at that moment)
I tried "g1 A[#2003+180]" but don't work.
With kind regards,
Frank
> Regards,
> Ray L.
> > Hi Tk,
> > Hope you can help.
> > Frank
Message: 6574 |
Date: 1/23/2013 |
Hi Frank,
I think you could temporarily switch to relative mode with G91 so:
G1 G91 A180 G90 (switch back to absolute if necessary)
or you could set the current A position to zero before the move with
G92 A0 G1 A180
HTH Regards TK
Message: 6581 |
Date: 1/24/2013 |
Hi TK,
You are always very quick with your answers :)
I will try it tomorrow but I think both will do the job.
I will use G92 A0, G1 A180 because it is more save (cant forget to use G90)
With kind regards,
Frank
> Hi Frank,
> G1 G91 A180
> G92 A0
> G1 A180
> HTH
> From: frank_19_88
> Sent: Wednesday, January 23, 2013 2:24 AM
> Subject: [DynoMotion] Re: A command gcodes
> Hello Ray and TK,
> With kind regards,
> Frank
> > Regards,
> > Ray L.
> > > Hi Tk,
> > > Hope you can help.
> > > Frank
