Is it possible to configure (KFLOP) all eight closed loop axis and if so, what is the procedure?
Which pins are used for Enc No. 5-8?
Thanks in advance
Group: DynoMotion
Message: 11433
Date: 4/22/2015
Subject: Re: 8 closed loop axis
Yes. What type of drives and option boards are you using with KFLOP?
Group: DynoMotion
Message: 11434
Date: 4/22/2015
At this point I have only kflop controller with 8 micro-step drivers (of course with 8 stepping motors) drivers are cheap Chinese with TB6600. None of the optional Dynomotion products .. :(
On Wednesday, April 22, 2015 5:10 PM, "doriczoran@... [DynoMotion]" <DynoMotion@yahoogroups.com> wrote:
Thanks in advance
Group: DynoMotion
Message: 11436
Date: 4/22/2015
In that case one approach would be to:
use 4 Step/Dir Outputs and 4 Encoder inputs available on KFLOP JP7.
use 4 Step/Dir Outputs on KFLOP JP5
multiplex the 4 encoder inputs normally on JP5 over to JP6 and connect 4 Encoders there. See the MuxEncoders.c example.
Group: DynoMotion
Message: 12039
Date: 7/31/2015
Thanks Tom,
i have one more question.
In case that i'm use the multiplexed 4 encoder inputs to JP6, therefore I can connect encoders to 3.3V inputs to JP6?
I think my encoders 5V output
Thanks in advance
Z
Group: DynoMotion
Message: 12045
Date: 8/1/2015
Hi Z,
That's not usually a problem. Please see this post:
