Group: DynoMotion Message: 5691 From: frank_19_88 Date: 9/18/2012
Subject: 3d scanner with probe
Hi TK,
Is it possible to make an 3D scan of an product with the Kflop?
Like this: http://www.youtube.com/watch?v=ZYJU1kwtzV4
Maybe with an plug-in to another program?
Ps. can I use the probe with mach3 to find centre points?
And if I find the x value left under the product and the x value at the left top of the product I can calculate the angle of the product. Can I also rotate my g-code within mach3 with that angle?
With kind regards,
Frank
Group: DynoMotion Message: 5692 From: Tom Kerekes Date: 9/18/2012
Subject: Re: 3d scanner with probe
Hi Frank,
I'm sure something like that could be created.  It would be fairly easy with a C program to collect the x,y,z points.  The points would then need to be converted to triangles if you wish to make an STL file.
Regarding Mach3 probing: probing is certainly possible.  See:
Regarding coordinate space rotation: I'm not sure.  Mach3 has Function Cfgs | Formulas that may work.
