Hardware requirements
The only real differences between a CNC machine and a 3D printer are in the tool head and the heated build platform. CNC machines use spindles, but some 3D printers use extruders (hot plastic extruder).
Extruder Nozzle
Heated Bed
Bowden Extruder
Metal Bowden Extruder for 1.75mm filament with stepper motor. Can be driven by KSTEP. (e.g.: All Metal V6 Hotend 1.75mm Bowden Extruder Prusa i3, around $25).
Adding a KNozz to your KFLOP
KNozz provides two Thermistor Inputs to allow KFLOP to monitor the temperature of both the Extruder Nozzle and Bed Heater Platform.  12-bit ADC converter provides better than 1 degree C temperature repeatability.
Learn more here:
Software requirements
CraftWare
Video
(Published on Feb 15, 2017)
